rodolfogomes
Protecting IP using vivado
Dear community,
I am currently having some concerns when it comes to the protection of our IPs.
From what I read/ researched herein, I got to understand that IP present in some VHDL source can be protected using the Xilinx's IP encrytption tool , which supports IEEE-1735-2014 Version 2 algorithm. However, how are the encrypted design sources placed in the uncrypted bitstream? is an attacker still able to steal my IP from a bitstream reverse engineering attack?
I am asking this, because I would like to sell IPs to be integrated in a costumer's design.... So, bitstream encryption is not a solution here.
Looking forward to hearing from you,
Rodolfo
maps-mpls
Mentor
Mentor
Some off the cuff thoughts...
Consider the IP encryption like a lock on your front door or on your bicycle...it will keep honest people honest.
And if you cannot trust your customer, how can you trust your customer's customers?
See this for some other ideas:  https://forums.xilinx.com/t5/Configuration/partial-reconfiguration-with-encrypted-partial-bitstream/td-p/873952
*** Destination: Rapid design and development cycles *** Unappreciated answers get deleted, unappreciative OPs get put on ignored list ***
