Red lines during floor planning in Device View
When I try to floorplan my design,  I get red lines for certain components and orange or grey for others as shown below :
What do these red lines mean ?
Those lines are called "bundle nets". The color coding indicates a rough number of nets between two pblocks. If you go to "Tools->Options" menu, select "Themes" then "Bundle nets', you will see the mapping between the color and the range of net counts (see the snapshot below). For example, a red line indicates that the number of nets between two pblocks is in the range of 61-200.
Cheers,
Jim
Cheers,
Jim
