Routing Switch Box
Is there any information from Xilinx about internal structue of routing switch boxes, on any FPGA generation? During manual routing I found out that by clicking on a switch-box pin, all possible routings are shown, but I am curious to see if there is any document about it.
Hi @hamze,
For manual placement and routing please go through the following links:
for ISE:
http://www.xilinx.com/support/documentation/sw_manuals/xilinx11/sse_p_routing_wire_manual.htm
http://www.xilinx.com/itp/xilinx10/isehelp/pp_p_process_manually_place_route.htm
http://www.xilinx.com/support/sw_manuals/2_1i/download/fpedit.pdf (chapter#3 42 page onwards switch box(chapter#3-44))
for Vivado
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2014_3/ug986-vivado-tutorial-implementation.pdf (lab#3)
http://www.xilinx.com/support/answers/54683.html
Arpan
Arpan
Thanks Arpan,
Actually I know how to do manual routing, I am just curious about structure of switch box, I already know there are few different popular architectures ( wilton, disjoint,...)...
is there any published information about this from xilinx?
@hamze , Did you get any reference to know internal structure of Xilinx FPGA switchboxes?
Goutham
it was long time ago, but what I remember was they are commercial secrets. However, by manual routing, you may get some information about possible connections.
