System Generator Error
We are working on FPGA design for wireless full duplex radio. To use the reference design in a stable way it has been suggested that; using MATLAB 2012b, Xilinx 14.4 and windows 7 should be installed. After I complete these requirements I configure the MATLAB and Xilinx 14.4 by using System Generator. Transmitter part of reference design has been worked properly however the receiver part creates some errors. We have checked these errors in forums and internet however we could not figure out how to get rid of that problem. So I am attaching the error log file and I hope someone can help me. Thank you for your time and interest.
Best Regards
ERRORS:
--------------------------------- Version Log ----------------------------------
Version                                 Path
System Generator 14.4                   C:/Xilinx/14.4/ISE_DS/ISE/sysgen
Matlab 8.0.0.783 (R2012b)               C:/Program Files/MATLAB/R2012b
ISE                                     C:/Xilinx/14.4/ISE_DS/ISE
Summary of Errors:
Error 0001: C:/Users/CASPER/AppData/Local/Temp/sysgentmp-CASPER/.xlmc...
     Block: 'untitled/CFO & Samp Buffer/Samp Buffer/FSM/MCode'
Error 0001:
Reported by:
Details:
:/Users/CASPER/AppData/Local/Temp/sysgentmp-CASPER/.xlmcode_work/rx_fft_ctrl_fsm/fd8/4000000/40e97500/51983cf635490e8689d52292e585204f/xlsim.c:1:
warning: -fPIC ignored for target (all code is position independent)
C:/Users/CASPER/AppData/Local/Temp/sysgentmp-CASPER/.xlmcode_work/rx_fft_ctrl_fsm/fd8/4000000/40e97500/51983cf635490e8689d52292e585204f/xlsim.c:
In function 'xlsim_update':
C:/Users/CASPER/AppData/Local/Temp/sysgentmp-CASPER/.xlmcode_work/rx_fft_ctrl_fsm/fd8/4000000/40e97500/51983cf635490e8689d52292e585204f/xlsim.c:435:
error: stray '\375' in program
error: expected '=', ',', ';', 'asm' or '__attribute__' before 't_23_1'
error: 't_23_1' undeclared (first use in this function)
error: (Each undeclared identifier is reported only once
error: for each function it appears in.)
C:/Users/CASPER/AppData/Local/Temp/sysgentmp-CASPER/.xlmcode_work/rx_fft_ctrl_fsm/fd8/4000000/40e97500/51983cf635490e8689d52292e585204f/xlsim.c:536:
error: 'st_lts_wa' undeclared (first use in this function)
error: expected ';' before 't_23_1'
Program
"C:/Xilinx/14.4/ISE_DS/ISE/gnu/MinGW/Beta/nt64/bin/x86_64-w64-mingw32-gcc.exe"
returned non-zero status (1).
Error occurred during "Simulation Initialization".
