UG946 flow not inferring OOC module as black box
I am trying to modify the script in UG946 to use HD design flow with my modules. When I open the top synthesized design checkpoint, the OOC module is not a black box. In the tutorial, the OOC modules are all black boxes after the topSynth step. Why doesn't this happen with my OOC module?
Thanks for the help.
Daniel
Re: UG946 flow not inferring OOC module as black box
I figured it out:
In the tutorial there is a top.prj file, and .prj files for each OOC module.
In the top.prj the have lines like:
verilog work "hdl/blackbox/usbf_bb.v"
verilog work "hdl/blackbox/or1200_bb.v"
Where the _bb files are empty. For example.
module usbf(signal names)
<signal declarations>
endmodule
I just did the same thing with the module I wanted to be a black box and it worked.
I figured it out:
endmodule
