siddadd
Unable to Floorplan
I imported my project from ISE into PlanAhead.
After carrying out the HDL flow and generating the bitstream, I am trying to floorplan my design.
The problem is none of the modules are showing up in the device tab on the right. Even when I highlight a primitive, I don't see anything. Attaching a screenshot of the same.
Is there some issue that can be fixed?
Siddharth
tanders
Look at the Implemented Design instead of the Netlist Design if you want to see the current placement.  Only constrained objects will be displayed in Netlist Design.
tanders
