[VHDL] Signals Assignment in Package -> how to?
Accepted Solution Solved
Accepted Solution
[ Edited ]
Hi All,
I know it's possible to declare signals in the package. But is it possible to assign the signals inside of the packages?
I'd like to write something like following:
package pkg_signals is
   type plan_t is (A, B);
   signal plan : plan_t;
signal sel : std_logic; end package pkg_signals; package body pkg_signals is plan <= A when sel = '1' else B; end pkg_signals;
Actually the plan_t is enum type... How can I compare enum types?
Can I write something like this:
signal abc : std_logic;
abc <= '1' when (plan = A) else '0';
Thank you!
Re: [VHDL] Signals Assignment in Package -> how to?
You seem to be doing some logic in the package
that would normaly be in the architecture of the design,
If you do need this logic in a package,
   then you need to write it as a function or procedure in the package.
      and call that from your architecture.
All Replies
Is it possible to assign signals inside of the packages? How? Please provide some example. Thanks
