Vivado 2020.1 synthesized away signals with KEEP attribute and strange FOR GENERATE behavior
I'm working on the register delay chains, but I'm running into some issues with FOR GENERATE.
This is what I want to do. But vidado completely synthesized away my BUF(...) and also FOR GENERATE blocks. How can I prevent vidado from removing my BUF?
This is how my code looks like.
    -- CONSTANT
    constant T0 : integer := 0; -- Delay
    constant T1 : integer := 1; -- Delay
    constant T2 : integer := 2; -- Delay
    constant T3 : integer := 3; -- Delay
    -- COMPONENT
    dn : chain_regs
        GENERIC MAP(
            n          => n,
            t          => 3,
            simulation => simulation
        PORT MAP(
            MRST_N   => MRST_N       ,
            CLK_T(0) => '0'          ,
            CLK_T(1) => CLK_T(T2)  ,
            CLK_T(2) => CLK_T(T3)  ,
            CIN      => std_logic_vector(to_unsigned(0 , n)),
            DIN      => U_DQ_IN      ,
            DOUT(0)  => open         ,
            DOUT(1)  => open         ,
            DOUT(2)  => FIN_DAT
I have KEEP attribute assigned to BUF and DOUT
-- LIBRARY
LIBRARY IEEE;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
package typdef_pkg is
        type bus_array is array(natural range <>) of std_logic_vector;
end package;
-- LIBRARY
LIBRARY IEEE;
USE IEEE.numeric_std.all;
use ieee.std_logic_unsigned.all;
-- use ieee.std_logic_arith.all;
use work.typdef_pkg.all;
-- ENTITY
ENTITY chain_regs IS --
    GENERIC(
        CONSTANT n    : positive := 18;  -- How many bits available in this DPRAM.
        CONSTANT t    : positive := 2;  -- Stages of this register chain.
        CONSTANT simulation : boolean := FALSE
    PORT(
        SIGNAL MRST_N     : IN    std_logic;
        SIGNAL CLK_T      : IN    std_logic_vector;
        SIGNAL CIN        : IN    std_logic_vector;
        SIGNAL DIN        : IN    std_logic_vector;
        SIGNAL DOUT       : OUT   bus_array(t-1 downto 0)(n-1 downto 0)
end chain_regs;
-- ARCHITECTURE
architecture rtl of chain_regs is
    -- CONSTANT
    -- SIGNAL
    SIGNAL buf : bus_array(t-1 downto 0)(n-1 downto 0);
    SIGNAL CLK : std_logic_vector(t-1 downto 0);
    -- DEBUG
    attribute mark_debug : string;
    attribute keep : string;
    attribute keep of buf     : signal is "true";
    attribute keep of DOUT    : signal is "true";
begin
    -- ASSIGN
    CLK  <= CLK_T;
    dout <= buf ;
    -- Bus DATA Sync
    PROCESS (DIN)
    BEGIN
        buf(0)   <= DIN  ;
    END PROCESS;
    -- Bus DATA Sync
    cas : FOR I IN 1 TO t-1 GENERATE
        PROCESS (MRST_N, CLK(I))
        BEGIN
            IF(MRST_N ='0')THEN -- Master Reset
                buf(I)  <= CIN;
            ELSIF(CLK(I)'EVENT AND CLK(I)='1')THEN
                buf(I)   <= buf(I-1)  ;
            END IF;
        END PROCESS;
    END GENERATE;
end rtl;
@myfingerhurt ,
Maybe this will help - https://www.xilinx.com/support/answers/54778.html
------------FPGA enthusiast------------
Consider giving "Kudos" if you like my answer. Please mark my post "Accept as solution" if my answer has solved your problem
Thank you for your reply, but I have already tried that.
KEEP, DONT_TOUCH none of these worked.
attribute dont_touch : string;
attribute keep of DIN : signal is "true";
attribute dont_touch of buf : signal is "{true|false}";
I also have tried this, failed on the compilation.
library synplify;
use synplify.attributes.all;
attribute syn_keep of buf : signal is true;
I have no idea, why my last post disappeared?
I have changed my latest code and skipping the synthesized away issue for now.
But I have another problem. Here you can see. My original VHDL was trying to do this.
buf_reg[0] to CLK[0],
buf_reg[1] to CLK[1],
buf_reg[2] to CLK[2].
Since the CLK[1] & CLK[2] were from the same source, so the vivado merged them into CLK[1], and connected CLK[1] to buf_reg[0] & buf_reg[1], left the buf_reg[2] connect with CLK[0].
So the synthesized result completely violates my original design.
Question: How can I keep vivado from swapping my CLK[]?
    dn : chain_regs
        GENERIC MAP(
            n          => n,
            t          => DAT_STAGES,
            inital     => std_logic_vector(to_unsigned(0 , n)),
        PORT MAP(
            MRST_N   => MRST_N       ,
            CLK_T(0) => CLK_T(T2)  ,
            CLK_T(1) => CLK_T(T1)  ,
            CLK_T(2) => CLK_T(T1)  ,
            DIN      => U_DQ_IN      ,
            DOUT(0)  => wDFF_DOUT(0) ,
            DOUT(1)  => wDFF_DOUT(1) ,
            DOUT(2)  => wDFF_DOUT(2)
        FIN_DAT <= wDFF_DOUT(2);
Thanks to my local technical support, I finally get it working.
They said that the std_logic_vector in my definition was in default (0 to 2)  order.
So the CLK was assigned in backward, and that was the problem.
And I solved my problem by changing my port definition explicit into this st_logic_vector(t-1 downto 0).
    GENERIC(
        CONSTANT inital : std_logic_vector ;  -- Default initial.
    PORT(
        SIGNAL CLK_T      : IN    std_logic_vector(t-1 downto 0);
        SIGNAL DIN        : IN    std_logic_vector(n-1 downto 0);
end chain_regs;
