sritchie
Vivado file extension reference
Is there a document that lists all the file types/extensions used in a Vivado project?
dpaul24
@sritchie,
I am afraid there isn't.Someone has laready asked before.
https://forums.xilinx.com/t5/Design-Entry/File-Extensions-Vivado/td-p/307949
You learn as you play with the tools from design entry to bitstream generation.
However as a start this doc should be helpful - UG893 "Using the Vivado IDE".
------------FPGA enthusiast------------
Consider giving "Kudos" if you like my answer. Please mark my post "Accept as solution" if my answer has solved your problem
Asking for solutions to problems via PM will be ignored.
sritchie
Do you know what the wpc file is for?
dpaul24
No. I have never come across it or the need to know about it.
Are you using Vivado or ISE?
sritchie
The wpc file is located in a folder called "wt" under the ".cache" folder.
I want to know if this requires to be included with files written to a version control database.
Thanks for your help so far.
dpaul24
@sritchie,
I don't think you should worry about it. Don't include it in your version control system. It will create more problems rather than releving.
It will be generated locally by the person using it.
You don't need to consider all 'Vinado generated files' for version control. See my reply in this post for the files needed to be considered for version control.
https://forums.xilinx.com/t5/Design-Entry/Why-does-copy-xcix-file-not-give-me-what-I-expect/m-p/825258#M15597
@sritchie
Like dpaul24, I also do not archive files that can be regenerated by the tools.  The following thread describes how I’ve been keeping Vivado archive size small.
https://forums.xilinx.com/t5/Design-Methodologies-and/Vivado-upgrade-and-archive/m-p/929863#M5390
Mark
dpaul24
Improving my answer, see the screenshot for the files that need consideration. One can find them easily by clicking on the Source File Properties and then expanding the Type drop-down. Don't forget the *.xpr, wcfg, xci and xcix types. I would say just use your common sense regarding the files that need version controlling.
