Visitor jmljob2010
Zynq-7000 - Vivado - Customize Block missing doc "Allow access to High OCM"
In Vivado, when using 'Customize Block' on the Zynq PS7 ip, we have the possibility to check the
'PS-PL Configuration' > 'General' > 'Address Editor' > 'Allow access to High OCM' option,
in order to "Allow address mapping to PS internal OCM at High Address".
When this checkbox is coched, Vivado activate (1) the PCW_USE_HIGH_OCM flag :
  set_property -dict [list CONFIG.PCW_USE_HIGH_OCM {1}] [get_bd_cells processing_system7_0]
We can see that this is flag is updated by Vivado in the following design files :
* BD source file ( such as project_1\project_1.srcs\sources_1\bd\design_1\design_1.bd )
* HW file (such as project_1\project_1.srcs\sources_1\bd\design_1\hw_handoff\design_1.hwh)
* PS7 config file (such as design_1_processing_system7_0_0.xml)
But when we export the HW Design platform and open it in SDK,
this OCM Remap flag can not be found in any file :
* We can see in the ps7_init.html file and empty section below the OCM REMAPPING title
* We can see in the ps7_init.c file some empty sections :
     // .. START: OCM REMAPPING
     // .. FINISH: OCM REMAPPING
Thus, could someboby explains how works this 'Allow access to High OCM' option ?
Because there is no info in the Processing System 7 v5.5 LogiCORE IP Product Guide (PG082) about this features
