valiciousx
average value of 4 signals
I'm new to VHDL programming and I try to make a module which calculates the average value of 4 signals. Then I have to use a decoder to display the value from binary to decimal on a Basys3 component. Here's my try but I don't know how to continue:
How to use a decoder to display the value on the component in decimal? Also, am I started in a correct way?
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
-- Uncomment the following library declaration if using
-- arithmetic functions with Signed or Unsigned values
--use IEEE.NUMERIC_STD.ALL;
-- Uncomment the following library declaration if instantiating
-- any Xilinx leaf cells in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
entity Average is
Port ( a1, a2, a3, a4: in std_logic_vector(7 downto 0);
result: out std_logic_vector(7 downto 0));
end Average;
architecture Behavioral of Average is
signal sum: std_logic_vector(7 downto 0);
begin
sum <= ("00" & a1)+a2+a3+a4;
result <= sum(9 downto 2) + sum(1);
end Behavioral;
drjohnsmith
http://freerangefactory.org/
bruce_karaffa
Do your inputs represent unsigned (0 to 255) or signed (-128 to 127) numbers? It makes a difference in how you sign extend before the addition.  Are you using VHDL 2008 or an earlier version?  Have you tried to simulate?  Simulation will help to find syntax and logical errors.  You have a clock on the board.  You should be using it.
A decoder can be just a look up table.  You only have 256 possible input combinations so it could fit into a BRAM.
samamherb
Please specify the type of input data (signed or unsigned). For converting from binary to BCD the below sample can be used.
process(AVG)
		variable AVG_TEMP : std_logic_vector(6 downto 0);
	begin
		AVG_TEMP := AVG(7 downto 1);
		case AVG_TEMP is
			when "0000000" => BCD(11 downto 1) <= "00000000000";
			when "0000001" => BCD(11 downto 1) <= "00000000001";
			when "0000010" => BCD(11 downto 1) <= "00000000010";
			when "0000011" => BCD(11 downto 1) <= "00000000011";
			when "0000100" => BCD(11 downto 1) <= "00000000100";
			when "0000101" => BCD(11 downto 1) <= "00000001000";
			when "0000110" => BCD(11 downto 1) <= "00000001001";
			when "0000111" => BCD(11 downto 1) <= "00000001010";
			when "0001000" => BCD(11 downto 1) <= "00000001011";
			when "0001001" => BCD(11 downto 1) <= "00000001100";
			when "0001010" => BCD(11 downto 1) <= "00000010000";
			when "0001011" => BCD(11 downto 1) <= "00000010001";
			when "0001100" => BCD(11 downto 1) <= "00000010010";
			when "0001101" => BCD(11 downto 1) <= "00000010011";
			when "0001110" => BCD(11 downto 1) <= "00000010100";
			when "0001111" => BCD(11 downto 1) <= "00000011000";
			when "0010000" => BCD(11 downto 1) <= "00000011001";
			when "0010001" => BCD(11 downto 1) <= "00000011010";
			when "0010010" => BCD(11 downto 1) <= "00000011011";
			when "0010011" => BCD(11 downto 1) <= "00000011100";
			when "0010100" => BCD(11 downto 1) <= "00000100000";
			when "0010101" => BCD(11 downto 1) <= "00000100001";
			when "0010110" => BCD(11 downto 1) <= "00000100010";
			when "0010111" => BCD(11 downto 1) <= "00000100011";
			when "0011000" => BCD(11 downto 1) <= "00000100100";
			when "0011001" => BCD(11 downto 1) <= "00000101000";
			when "0011010" => BCD(11 downto 1) <= "00000101001";
			when "0011011" => BCD(11 downto 1) <= "00000101010";
			when "0011100" => BCD(11 downto 1) <= "00000101011";
			when "0011101" => BCD(11 downto 1) <= "00000101100";
			when "0011110" => BCD(11 downto 1) <= "00000110000";
			when "0011111" => BCD(11 downto 1) <= "00000110001";
			when "0100000" => BCD(11 downto 1) <= "00000110010";
			when "0100001" => BCD(11 downto 1) <= "00000110011";
			when "0100010" => BCD(11 downto 1) <= "00000110100";
			when "0100011" => BCD(11 downto 1) <= "00000111000";
			when "0100100" => BCD(11 downto 1) <= "00000111001";
			when "0100101" => BCD(11 downto 1) <= "00000111010";
			when "0100110" => BCD(11 downto 1) <= "00000111011";
			when "0100111" => BCD(11 downto 1) <= "00000111100";
			when "0101000" => BCD(11 downto 1) <= "00001000000";
			when "0101001" => BCD(11 downto 1) <= "00001000001";
			when "0101010" => BCD(11 downto 1) <= "00001000010";
			when "0101011" => BCD(11 downto 1) <= "00001000011";
			when "0101100" => BCD(11 downto 1) <= "00001000100";
			when "0101101" => BCD(11 downto 1) <= "00001001000";
			when "0101110" => BCD(11 downto 1) <= "00001001001";
			when "0101111" => BCD(11 downto 1) <= "00001001010";
			when "0110000" => BCD(11 downto 1) <= "00001001011";
			when "0110001" => BCD(11 downto 1) <= "00001001100";
			when "0110010" => BCD(11 downto 1) <= "00010000000";
			when "0110011" => BCD(11 downto 1) <= "00010000001";
			when "0110100" => BCD(11 downto 1) <= "00010000010";
			when "0110101" => BCD(11 downto 1) <= "00010000011";
			when "0110110" => BCD(11 downto 1) <= "00010000100";
			when "0110111" => BCD(11 downto 1) <= "00010001000";
			when "0111000" => BCD(11 downto 1) <= "00010001001";
			when "0111001" => BCD(11 downto 1) <= "00010001010";
			when "0111010" => BCD(11 downto 1) <= "00010001011";
			when "0111011" => BCD(11 downto 1) <= "00010001100";
			when "0111100" => BCD(11 downto 1) <= "00010010000";
			when "0111101" => BCD(11 downto 1) <= "00010010001";
			when "0111110" => BCD(11 downto 1) <= "00010010010";
			when "0111111" => BCD(11 downto 1) <= "00010010011";
			when "1000000" => BCD(11 downto 1) <= "00010010100";
			when "1000001" => BCD(11 downto 1) <= "00010011000";
			when "1000010" => BCD(11 downto 1) <= "00010011001";
			when "1000011" => BCD(11 downto 1) <= "00010011010";
			when "1000100" => BCD(11 downto 1) <= "00010011011";
			when "1000101" => BCD(11 downto 1) <= "00010011100";
			when "1000110" => BCD(11 downto 1) <= "00010100000";
			when "1000111" => BCD(11 downto 1) <= "00010100001";
			when "1001000" => BCD(11 downto 1) <= "00010100010";
			when "1001001" => BCD(11 downto 1) <= "00010100011";
			when "1001010" => BCD(11 downto 1) <= "00010100100";
			when "1001011" => BCD(11 downto 1) <= "00010101000";
			when "1001100" => BCD(11 downto 1) <= "00010101001";
			when "1001101" => BCD(11 downto 1) <= "00010101010";
			when "1001110" => BCD(11 downto 1) <= "00010101011";
			when "1001111" => BCD(11 downto 1) <= "00010101100";
			when "1010000" => BCD(11 downto 1) <= "00010110000";
			when "1010001" => BCD(11 downto 1) <= "00010110001";
			when "1010010" => BCD(11 downto 1) <= "00010110010";
			when "1010011" => BCD(11 downto 1) <= "00010110011";
			when "1010100" => BCD(11 downto 1) <= "00010110100";
			when "1010101" => BCD(11 downto 1) <= "00010111000";
			when "1010110" => BCD(11 downto 1) <= "00010111001";
			when "1010111" => BCD(11 downto 1) <= "00010111010";
			when "1011000" => BCD(11 downto 1) <= "00010111011";
			when "1011001" => BCD(11 downto 1) <= "00010111100";
			when "1011010" => BCD(11 downto 1) <= "00011000000";
			when "1011011" => BCD(11 downto 1) <= "00011000001";
			when "1011100" => BCD(11 downto 1) <= "00011000010";
			when "1011101" => BCD(11 downto 1) <= "00011000011";
			when "1011110" => BCD(11 downto 1) <= "00011000100";
			when "1011111" => BCD(11 downto 1) <= "00011001000";
			when "1100000" => BCD(11 downto 1) <= "00011001001";
			when "1100001" => BCD(11 downto 1) <= "00011001010";
			when "1100010" => BCD(11 downto 1) <= "00011001011";
			when "1100011" => BCD(11 downto 1) <= "00011001100";
			when "1100100" => BCD(11 downto 1) <= "00100000000";
			when "1100101" => BCD(11 downto 1) <= "00100000001";
			when "1100110" => BCD(11 downto 1) <= "00100000010";
			when "1100111" => BCD(11 downto 1) <= "00100000011";
			when "1101000" => BCD(11 downto 1) <= "00100000100";
			when "1101001" => BCD(11 downto 1) <= "00100001000";
			when "1101010" => BCD(11 downto 1) <= "00100001001";
			when "1101011" => BCD(11 downto 1) <= "00100001010";
			when "1101100" => BCD(11 downto 1) <= "00100001011";
			when "1101101" => BCD(11 downto 1) <= "00100001100";
			when "1101110" => BCD(11 downto 1) <= "00100010000";
			when "1101111" => BCD(11 downto 1) <= "00100010001";
			when "1110000" => BCD(11 downto 1) <= "00100010010";
			when "1110001" => BCD(11 downto 1) <= "00100010011";
			when "1110010" => BCD(11 downto 1) <= "00100010100";
			when "1110011" => BCD(11 downto 1) <= "00100011000";
			when "1110100" => BCD(11 downto 1) <= "00100011001";
			when "1110101" => BCD(11 downto 1) <= "00100011010";
			when "1110110" => BCD(11 downto 1) <= "00100011011";
			when "1110111" => BCD(11 downto 1) <= "00100011100";
			when "1111000" => BCD(11 downto 1) <= "00100100000";
			when "1111001" => BCD(11 downto 1) <= "00100100001";
			when "1111010" => BCD(11 downto 1) <= "00100100010";
			when "1111011" => BCD(11 downto 1) <= "00100100011";
			when "1111100" => BCD(11 downto 1) <= "00100100100";
			when "1111101" => BCD(11 downto 1) <= "00100101000";
			when "1111110" => BCD(11 downto 1) <= "00100101001";
			when "1111111" => BCD(11 downto 1) <= "00100101010";
			when others => BCD <= (others => '0');
		end case;
		BCD(0) <= AVG(0);
	end process;
I'm a freelance VHDL developer and HDL designer.
drjohnsmith
If you are gogin to use this format
    then I woudl strongly sugest that you use a slightly different format,
e.g
become
when B"000_0101" => BCD( 10 downto 0 )  <= B" 000_0000_1000";
you will make many fewer mistakes.
or if your using 2008,
when 7x"05" => BCD( 10 downto 0 )  <= 11x"008";
