Newbie skseofhek
petalinux pmod CAN using SPI interface
Hi.
I'm using zybo-z7 10(zynq 7000) and pmod CAN.
I'm trying to build pmod CAN petalinux user app.
But first of all, I want to handle spi transfer, so I build spi example code.
I'm using petalinux 2017.4 and vivado 2018.2.
And hardware design referenced from here :
https://reference.digilentinc.com/learn/programmable-logic/tutorials/pmod-ips/start
and device tree (in ~/CAN_fpga/project-spec/meta-user/recipes-bsp/device-tree/files/system_user.dtsi) :
/include/ "system-conf.dtsi"
&spi0 {
  is-decoded-cs = <0>;
  num-cs = <1>;
  status = "okay";
  spidev@0x00 {
    compatible = "spidev";
    spi-max-frequency = <10000000>;
    reg = <0>;
and the user app code:
#include <stdio.h>
#include <string.h>
#include <stdint.h>
#include <stdlib.h>
#include <unistd.h>
#include <sys/mman.h>
#include <fcntl.h>
#include <sys/types.h>
#include <sys/stat.h>
#include <sys/ioctl.h>
#include <linux/types.h>
#include <linux/spi/spidev.h>
#define SPI_DEV    "/dev/spidev32766.0"
int main(void)
    int fd, i;
    int rbuf[128];
    const char * name = SPI_DEV;
    int readcount = 8;
    int msglen = 8;
    if((fd = open(SPI_DEV, O_RDWR))<0)
        perror("Open error: ");
        exit(-1);
    printf("Open success\n");
    dumpstat(name, fd);
    printf("before do_msg\n");
    if (msglen)
        do_msg(fd, msglen);
    printf("after do_msg\n");
    if (readcount)
        do_read(fd, readcount);
    return 0;
static void do_read(int fd, int len)
    unsigned char    buf[32], *bp;
    int        status;
    /* read at least 2 bytes, no more than 32 */
    if (len < 2)
        len = 2;
    else if (len > sizeof(buf))
        len = sizeof(buf);
    memset(buf, 0, sizeof buf);
    status = read(fd, buf, len);
    if (status < 0) {
        perror("read");
        return;
    if (status != len) {
        fprintf(stderr, "short read\n");
        return;
    printf("read(%2d, %2d): %02x %02x,", len, status, buf[0], buf[1]);
    status -= 2;
    bp = buf + 2;
    while (status-- > 0)
        printf(" %02x", *bp++);
    printf("\n");
static void do_msg(int fd, int len)
    struct spi_ioc_transfer    xfer[2];
    int            status;
    memset(xfer, 0, sizeof xfer);
    if (len > sizeof buf)
        len = sizeof buf;
    buf[0] = 0xaa;
    xfer[0].tx_buf = (unsigned long)buf;
    xfer[0].len = 1;
    xfer[1].rx_buf = (unsigned long) buf;
    xfer[1].len = len;
    printf("before do_msg ioctl\n");
    status = ioctl(fd, SPI_IOC_MESSAGE(2), xfer);
    printf("after do_msg ioctl\n");
    if (status < 0) {
        printf("status : %d\n", status);
        perror("SPI_IOC_MESSAGE");
        return;
    printf("response(%2d, %2d): ", len, status);
    for (bp = buf; len; len--)
    printf("\n");
static void dumpstat(const char *name, int fd)
    __u8    lsb, bits;
    __u32    mode, speed;
    if (ioctl(fd, SPI_IOC_RD_MODE32, &mode) < 0) {
        perror("SPI rd_mode");
        return;
    if (ioctl(fd, SPI_IOC_RD_LSB_FIRST, &lsb) < 0) {
        perror("SPI rd_lsb_fist");
        return;
    if (ioctl(fd, SPI_IOC_RD_BITS_PER_WORD, &bits) < 0) {
        perror("SPI bits_per_word");
        return;
    if (ioctl(fd, SPI_IOC_RD_MAX_SPEED_HZ, &speed) < 0) {
        perror("SPI max_speed_hz");
        return;
    printf("%s: spi read mode 0x%x, %d bits %sper word, %d Hz max\n",
        name, mode, bits, lsb ? "(lsb first) " : "", speed);
I want to control spi in duplex mode using ioctl() bolded above code.
But the result is :
- SPI transfer timed out   -> ioctl() function doesn't work properly, I think.
 Could you give me some advice?
