trouble making a module into RM because the module appears to be outside the top in hierarchical source viewer
We have top module VHDL and use mixed HDL sub-modules under it.  I can't make this sub-module "WORK_MAC" into RM and got the following error message when I "create Partition Definition":
The file /../project_1/...../vlog/WORK_MAC.v that contains the module top WORK_MAC is also used elsewhere in the design in a different context so cannot be made into reconfigurable module.
I did see this sub-module appear outside the top in hierarchy source viewer.  I think it's not being parsed correctly so I have tried manual compile order but it does not help.
In the top module VHDL, we have:
dut_WORK_MAC : WORK_MAC (instantiation)
component WORK_MAC  (declaration)
then we have a WORK_MAC.v
What can I do so that I can make it a RM? I'm using Vivado v2018.3.1 and DFX project flow.
Thanks in advance
Tags (3)
Hi, @annchen ,
Can the project be synthesized properly without the PR flow?
Can you also try the flow in Vivado 2020.1?
Thank you so much for replying!
Yes, the project is synthesized properly before I load the project.xpr and convert it to DFX project.  My coworker even tried to re-create the project and still got many sub-modules list outside the top module's hierarchy.  We tried to make the sub-module "WORK_MAC" a black box (use WORK_MAC_BBOX.v) in order to make it a RM (and it worked).  But then the problem becomes how we can put the original WORK_MAC.v back into place.  When I load WORK_MAC.v as a source file for the original WORK_MAC (the 2nd RM), I now have two identical WORK_MAC existing outside the top hierarchy.
We also have Vivado 2019.2 as of now.  How can we get 2020.1?
Please confirm you add the source files of 2nd RM with PR(DFX)_Wizard.
On the Partition Definitions tab, I click on the 2nd RM and right click on the "Edit Reconfiguration module" to add source file WORK_MAC.v.  All the sub-modules of WORK_MAC appear with ? mark in front.  So I have to add the whole directory of Verilog files since they are just too many.
Yes, all the sub-modules source files of top dynamic cell should be added.
You can also choose to OOC synthesize the RM module in a separate project and export the netlist.
I even went thru the OOC synth step of the 2nd RM (orginal WORK_MAC.v). Implementation of the 2nd RM has error saying the port or module name does not match.  Anyway these steps each take a while for the graph to be updated/evaluated.  In a second project, I can't reproduce all these steps.  So I'm seeking solutions of not needing to make it a black box in order to make it a RM.
You can consider to provide a test design if possible.
Can the tool's script for processing source files into hierarchy handle VHDL top module and mixed VHDL/Verilog sub-modules?
