microchip_zhang
when using auto infer interface chooser ,signal m_axis_s2mm_valid is left out of the bus ,why ?
firstly , I  use the GUI below
then , I get the result below , but signal m_axis_s2mm_valid is left out of the bus ,why  ?
florentw
Hi @microchip_zhang
This is probably because the GUI is expecting the name to be _tvalid and not only _valid
Florent
