zynq7000 write data to sd card from ddr
Hi there,
I'm working on SD card access of zynq7000 FPGA board.
I'm using VIVADO 2018.2 and z turn board.
while I'm writing the data from DDR to SD card ,it is storing as 8 bits(ASCII) per one address as it is coming from DDR.
But I want to store the data in SD card as 16 bits per one address location. And I'm using example code xilffs_polled_exapmle.c which is given in XILINX SDK installation folder.
For that what should I do in that C code and i want to store in HEXA decimal format directly to SD card.
Thanks in advance.
