Scholar dwisehart
Add channel to Vivado sweep and scan plots
From Vivado you can make very nice scan plots from a sweep.
The software knows which port it is scanning.  It would be very helpful if the Summary included the RX channel.  In this case it is MGT_X1Y33.  When you are sweeping a lot of ports it is easy to lose track of which port a particular plot is for.
Daniel
Re: Add channel to Vivado sweep and scan plots
This is a good input. Also, you can rename the plot with the Rx channel while adding it.
Scholar dwisehart
Thanks, it is true you can set the description when you create the sweep.  But it is also true that the Create Sweep dialog shows you the port.  It would not seem hard to add the port to the summary and it is vital information for every sweep or scan.  Please consider it a suggestion.
Daniel
Is it possible to save the 2D Scan Plot to a file as an image file ?
I'm looking to automate a large number of RX channels using TCL in Vivado 2014.3
thanks,
jamieson
