Cable connection times out w/ iMPACT/XMD and cannot clean cable lock
Neither iMPACT's cleancablelock nor XMD's xclean_cablelock commands help. How can I fix the connection without restaring the board or re-connecting the usb cable? See details below.
Using uBlaze on ML505, 9.2i tools (EDK 9.2.02 ISE 9.2.04), Linux
REPORTS
XMD prints:
ERROR set configuration. strerr=Connection timed out.
iMPACT prints:
Checking cable driver.
write cmdbuffer failed 20000020.
Loopback test failed. ...
Cable connection failed.
HOW IT GETS TO THIS STATE
0. Normal usage, iMPACT works, upload bitstream, disconnect. Then connect w/ XMD and debug. Exit XMD without stopping uBlaze. So, at the time of cable connection conflict the uBlaze is still running.
1. Upload bitstream w/ iMPACT, but forgetting to disconnect
2. XMD connection fails, exit
4. $ impact -batch; And run cleancablelock. Does not help (i.e. not able to connect later)
5. $ xmd; And run xclean_cablelock. Does not help (i.e. not able to connect later)
WHAT HELPED
Restarting the board and disconnecting/re-connecting USB cable.
However, since I am connecting to the computer remotely, this is not always an option.
OTHER
I have tried removing and adding usb module.
$ lsusb (Shows Xilinx Platform Cable connected)
$ sudo modprobe  -r -v usbhid
$ lsusb (still shows the Xilinx Platform Cable connected)
$ sudo modprobe usbhid
Note that "$lsmod |grep usb" returns usbhid and usbserial modules, but I am not using usb2serial adapter in this configuration, so it must be usbhid.
- Why could be the cable still locked after running the clean commands in iMPACT and XMD?
- Am I properly restaring the USB device?
Victor
Tags (2)
Visitor adacsys
Re: Cable connection times out w/ iMPACT/XMD and cannot clean cable lock
I have exactly the same problem, with ML605.
Would you please give the final solution?
I work around this solution by reconnecting the USB cable. It is not ideal, but at the time of this post I haven't found another workaround. Maybe it was fixed in the latest tools? I am still on EDK 9.2. It'd be great to hear if anyone knows the fix.
Victor
Visitor krlarsen
From the libusb-driver README file:
Locked cables
If you get the message 'The cable is being used by another application.' from
impact, try running the following command:
echo -e 'cleancablelock\nexit' | impact -batch
 This seemed to work for me.
EDIT:
Nevermind! I hadn't noticed you've already tried this.
Newbie oespino
I have the same problem with 12.4 on RedHat Enterprise 5. Neither iMPACT's cleancablelock nor XMD's xclean_cablelock commands works.
Anyone got some feeback?
Newbie msanchez
I'm having the same problem. Did anyone could solve it?
Regards.
