Visitor jyothi.nayak
Can i use parallel cable 4 instead of multilinx cable with chipscope
I want to use chipscope on my platform which has Xilinx FPGA. I have downloaed Free 60 day trial Xilinx ISE 10.1 software which has chipscope tool. Chipscope data sheet says we need MULTILINX cable to connect host to platform. Can i use parallel cable in place of MULTILINX cable since i dont have that currently?
Re: Can i use parallel cable 4 instead of multilinx cable with chipscope
Sorry to put the question wrong earlier. My question is can I use parallel cable instead of MULTILINX cable to connect my host system which has xilinx chipscope tool installed to Design under test?
You must be looking at really old datasheet if it says that ChipScope supports Multilinx as that cable has been discontinued.
Parallel Cable 4 will work just fine.
