Visitor gvleming03
ChipScope script problem
Hi all,
I'm having problems launching ChipScope from both ISE and the command line in Ubuntu Linux 10.04. In either case, the following errors get printed in Terminal:
/opt/Xilinx/12.1/ISE_DS/ISE/bin/lin/unwrapped/cs_common.sh: 76: XIL_DIRS[0]=/opt/Xilinx/12.1/ISE_DS/ISE: not found
/opt/Xilinx/12.1/ISE_DS/ISE/bin/lin/unwrapped/cs_common.sh: 152: Syntax error: Bad for loop variable
I'm not too familiar with scripting, but it seems that this "cs_common.sh" script is broken. I was able to fix a simpler problem in this script (variable not found error), but I'm not sure what to do about these.  I'm using a bash shell, and from what I've learned in the 15 minutes I've been reading about bash scripting, the looping construct is incorrect. Here's the code:
# Walk through the XILINX directories looking for the first JRE
  assigned=0
  for ((i=0; i<${#XIL_DIRS[@]}; i++))
  do
    tstdir="${XIL_DIRS[$i]}/java6/${XIL_CS_OS}/jre"
    if [ $assigned -eq 0 -a -d $tstdir ]
    then
      assigned=1
      XIL_CS_JRE=$tstdir
    fi
  done
I know you can't use this C-like for-loop, but I'm not sure how to alter it so that it has the same behavior in bash script syntax.
As for the other error involving XIL_DIRS, the code is this:
# Break MYXILINX and XILINX into components. Store them in XIL_DIRS
SaveIFS=$IFS
The comment is self-explanatory, but it doesn't look like they store anything in XIL_DIRS (which should be an array). Do I need to just declare this variable as an array, or is there something more to it?
Any help resolving these issues would be much appreciated. I've attached the entire script for reference.
Newbie anunakin
Re: ChipScope script problem
I'm using ISE 12.3 under Linux Ubuntu 10.04 and I have same problem here Chipscope not working...
############ EDIT #############
Found a solution, posts 8 and 9 solved it for me, we need set /bin/sh to /bin/bash
http://xlnx.lithium.com/t5/Installation-and-Licensing/ISE-12-1-Linux-Installs/m-p/75824#M1471
Anyone found a solution to this?
Same problem using ISE 14.7 on ubuntu 13.10
