Error when using ILA core
Hello, i like to learn debugging and so i add an ila-core to my design. After i created my design, i got the following System error message: " [Common 17-70] Application Exception: Failed to stitch checkpoint 'c:/Projekte/TestDebug/TestDebug.srcs/sources_1/bd/system/ip/system_DataSink_0_0/system_DataSink_0_0.dcp' at cell 'system_i/DataSink_0'." when i try to open the "synthesized design". Can somebody please tell me, what i have to do? I like to debug the Signal "q -> d" in my design (see attachment). I'am using an arty-board. Thank you, regards.
Re: Error when using ILA core
Hi @deppenkaiser,
  1. Remove system ILA from the design.
  2. Then add ILA from IP catalog and do the required connection. Please go through page-105 and 106 of https://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_2/ug994-vivado-ip-subsystems.pdf
Arpan
Hi @deppenkaiser,
Is there any specific reason behind using system ILA?
Can you please try with ILA only? Which Vivado version you are using?
Arpan
Hi @deppenkaiser,
Please debug using the steps mentioned in the accepted solution post in this forum thread and check if it helps: https://forums.xilinx.com/t5/Welcome-Join/ERROR-Common-17-70-Application-Exception-Failed-to-stitch/td-p/663625.
Since you are learning debugging, UG936 tutorial in debugging is always helpful: https://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_4/ug936-vivado-tutorial-programming-debugging.pdf
Thanks & Regards,
Prathik
Search for documents/answer records related to your device and tool before posting query on forums.
Search related forums and make sure your query is not repeated.
Please mark the post as an answer "Accept as solution" in case it helps to resolve your query.
Helpful answer -> Give Kudos
Hello arpansur,
i'am using "Vivado 2016.4". I used "system ila", because i right click on a signal and select "Debug". My earlier experience was, that this is possible and meaningfull to debug on Hardware. But i saw, that i should have more practice; so i tried a most simple design to have a good overview about debugging possibilities. Now, with this "simple design" i have Problems.
I need only a simple design where i can get some expirences.
Hi @deppenkaiser,
As you are seeing crash issue can you please try adding ILA instead of system ILA? Also you can use setup debug after synthesis to insert ILA.
Arpan
Hi prathikm, i can't open the pdf, so i will try it later again. I made a microblaze design and i need to debug it. But i do not undestand the meaning of the many signals that i am able to select. I like to see the axi bus timing. So i want to get more practice and - therefore i can learn - i make a smaller design with a simple logic. But i get this error message...
regards
Hello arpansur,
i made a screenshot, so you can see what happens when i click on "Synthesis->Open Sythesized Design->Set up Debug".
You told me, that i can use "ILA" instead of "System ILA". Should i select it in the IP-Repository? I never did it before :-)
regards
Hi @deppenkaiser,
Arpan
