Observer cnie
How could I change the chipscope ila counter width in PlanAhead?
Hi guys,
When I tried to insert Chipscope from the netlist in PlanAhead, I am not able to enable to the counter of ILA, any idea?2012-11-14_155932.png
Re: How could I change the chipscope ila counter width in PlanAhead?
Counter width and match unit selection can be changed by selecting the Trigger ports under the ILA and changing the attributes .Please check the snapshot
Observer cnie
And it seems the ILA Trigger Match Unit Types are also unchangeable from PlanAhead GUI.
Observer cnie
Got it, thank you.
