Visitor milagorobets
ILA Debug Core Clock problem ("Failed to get a response from the Debug Core Hub")
I am trying to debug my IP design using ChipScope.
The S_AXI_ACLK pin of my IP is connected to FCLK_CLK0, and set to 100MHz.
I have tried setting up the debugging core with FCLK_CLK0 as the clock domain, but that produces an error:
ERROR: [Labtools 27-147] vcse_server: XSDB Master timed out.
ERROR: [Labtools 27-1437] Failed to get a response from the Debug Core Hub on device xc7z020_1 (JTAG device index = 1), in user chain = 1.
Resolution:
1) Verify that the clock signal connected to the debug core is clean and free-running.
2) Verify that the clock connected to the debug core meets all timing constraints.
I then switched the debugging core to use FCLK_CLK1 as the clock domain, but that produces the same error. I have set the frequency of CLK1 to 200MHz, but that doesn't change anything.
The FCLK_CLK0 signal isn't connected to anything except S_AXI_ACLK on my design. Any ideas for what I can do to get it to work?
Re: ILA Debug Core Clock problem ("Failed to get a response from the Debug Core Hub")
hello,
please try using following commands.
set DEBUG_HUB_CLK_PIN [get_pins dbg_hub/XSDB_CLK_I]
disconnect_net -net [get_nets -of $DEBUG_HUB_CLK_PIN] -objects $DEBUG_HUB_CLK_PIN
connect_net -net [get_nets <continously running clock net name>] -objects $DEBUG_HUB_CLK_PIN
hope this helps
thanks,
Shreyas
Try to search answer for your issue in forums or xilinx user guides before you post a new thread.
Kindly note- Please mark the Answer as "Accept as solution" if information provided solves your query.
Give Kudos (star provided in left) to a post which you think is helpful and reply oriented.
Give Kudos (star provided in right) to a post which you think is helpful and reply oriented.
Check if you have any timing violations in your design.
Thanks,Vijay
