Visitor firo7830
ILA error when programming PCIe design
Hi guys!
    I want to use a PCIe example on vc709 board and I am using Vivado 2014.1 and I try to capture some signals coming out of the PCIe example,but after I insert the ILA core,then open hardware manager ,it come out a error like this.
below is my dubug core :
Actually I have read ug936 and ug908 ,the step is absolutely right. And I have also checked some AR such as 52939/54568/54355/51901 /56616 or some forums ,so I know the reason may be the clock. In fact the PCIe example's sysclk comes from the golden fingers, before I didn't insert the board into the PC,but when doing this,it still don't work.And I also used the sysclk /user_clk ,which neither not.
   So tell me what do I miss or what shall I do?please advise!
THX!
Firo
Tags (3)
Visitor firo7830
Re: ILA error when programming PCIe design
Hi guys!
My problem is solved,actually the answer is very simple,just ignore the message...
THX !
firo
Community Manager
Community Manager
Is it possible to try in a latest version?
Sikta
Moving to correct board.
Thanks,Vijay
Visitor firo7830
Hi,Sikta
What do you mean? do you think I should use the latest vivado version?and what articles does Xilinx has about PCIe debug process using vivado?
THX!
Firo
Visitor firo7830
Hi,Vijay
Actually I don't know what's your thought,please tell me in details.When I generate the project,I just choose the VC709 board.So the PCIe example's XDC file is suit for the VC709.
THX!
Firo
Visitor firo7830
Hi guys!
THX !
firo
