Visitor jvoven
Re: fails to load include Zynq7 Processing System IP in block design
@xilinxacct @stephenm
Thank you for your suggestions. So far I did not had any progress on this. I will clearly describe the steps I undertook to get to this point so maybe you can reproduce it.
1. I installed a fresh copy of window 10 professional 64 bit from this link (https://www.microsoft.com/software-download/windows10).
2. I updated my windows to the newest version using windows updater. I now run version 1809, OS build 17763.195
3. Download the latest Vivado 2018.3 web installer.
4. I install Vivado webpack edition using all the default settings.
5. I create a new empty project with a zynq 7 series device (tried multiple ones, all give same result)
6. I create a new empty block design.
7. I press the '+' icon to add IP and select the zynq 7 series processing system
8. I see the following error message:
create_bd_cell -type ip -vlnv xilinx.com:ip:processing_system7:5.5 processing_system7_0
WARNING: [IP_Flow 19-3331] Invalid parameters found in dependency constraints of 'ADDRBLOCK_RANGE.S_AXI_ACP.ACP_QSPI_LINEAR'
WARNING: [IP_Flow 19-3553] Error found in parameter dependencies in XGUI files.
ERROR: [IP_Flow 19-3428] Failed to create Customization object design_1_processing_system7_0_0
CRITICAL WARNING: [IP_Flow 19-973] Failed to create IP instance 'design_1_processing_system7_0_0'. Error during customization.
ERROR: [BD 41-1712] Create IP failed with errors
ERROR: [BD 5-7] Error: running create_bd_cell -vlnv xilinx.com:ip:processing_system7:5.5 -type ip -name processing_system7_0 .
ERROR: [Common 17-39] 'create_bd_cell' failed due to earlier errors.
To exclude problems with my hardware, I tried the same on a virtual system on another system. This results in the same error message.
Since I have nothing else installed on my system, the problems suggest an incompatibility between the latest Windows 10 and Vivado. I also tried older versions of Vivado, which gave me the same error.
Your help is much appreciated.
Visitor jvoven
This problem is solved by installing an older build of windows 10. After reinstalling my pc with Windows 10 pro 64 bit, Version 1803, OS build 17134.472 the problem is gone. Since Xilinx states that Windows 10 1809 is supported, I consider this as a bug.
Visitor jvoven
Visitor yaacov
I have the exact same issue, also on Win 10 1809. I've got no easy way to get my computer back to 1803. Any other solution/workaround ?
