Participant mkru
Release date of Vivado 2018.3
Is it known when Vivado 2018.3 will be released?  Or maybe instead of 2018.3 there will be a jump to 2019.1? Anyway, does anyone know when we can expect new version that is said to fix some bugs?
Re: Release date of Vivado 2018.3
Hi @mkru,
Vivado 2018.3 is scheduled to be released on early December 2018. I unfortunately cannot provide you with a specific date.
Andre Guerrero
Product Applications Engineer
Hi @mkru,
Andre Guerrero
Participant frosteyes
Hi @anunesgu
I guess it is the same for the SDK / linux?
Does it mean that 2018.4 is skipped, and we should expect 2019.1 instead?
Claus
Hi @frosteyes
You are correct. The same apply to SDK, and we do not plan on releasing 2018.4.
Andre Guerrero
Hi @anunesgu
Thanks for the info.
Do you know what the plan is for which OS to support?
More specific we are using an Ubuntu 16.04 solution now, and would like to be ready when you are ditching Ubuntu 16.04, and when you introduce 18.04 support.
I could imagine that either 2018.3 or 2019.1 would be the first version with Ubuntu 18.04 support, and that 2018.3 would be your last version with 16.04 support?
If this is the case I would plan for upgrading to Ubuntu 18.04 in Q1 2019.
Claus
Hi @frosteyes,
We try to leave one question/issue per thread, so would you please re-post your last question on the Installation and Licensing board? https://forums.xilinx.com/t5/Installation-and-Licensing/bd-p/INSTALLBD
Thank you.
Andre Guerrero
hi @anunesgu
Yes of cause. And sorry I hijacked this thread with the question
Claus
Observer peimann
@anunesgu,
Thanks for giving us an indication of schedule.
An answer with I don't know is much better than misdirection, every time.
Cheers!
peimann
Kind Regards,
Peimann, S. M.
Toddlers are the Storm-Troopers of the Great God Entropy.
Physics: Not Just a Good Idea, It's THE LAW.
Hi all,
Just updating this thread, Vivado 2018.3 is now officially available.
You can download it from the link https://www.xilinx.com/support/download.html
Andre Guerrero
