Observer fen1xl
SmartLynq updating fail
Hi. I would like to update SmartLynq. On SmartLynq display: "2017.2 SAFE". I try to update: USB or Ethernet, Vivado 2017.4, update_hw_firmware -reset. But no effect, although Vivado write "SmartLynq success updated". When it rebooted, on display the same "2017.2 SAFE". How can I update it?
Re: SmartLynq updating fail
Hi @fen1xl,
Could you please try to do the update process in the AR https://www.xilinx.com/support/answers/71826.html. The initial part or the AR is explaining the method that you already tried. Please scroll down and try the alternative method named Alternative update process with XSDB.
Please let me know if that still does not work.
Thank you,
Andre Guerrero
Product Applications Engineer
Observer fen1xl
Thanks for your reply. I tried, but unfortunately it doesn't work for me too.
Could you please try the following command and share the outcome.
update_hw_firmware -format -reset
Harshit
Observer fen1xl
It doesn't work for me.
Hi @fen1xl ,
I will send you a private message with an alternative procedure to try.
Andre Guerrero
