Vivado chipscope error
refresh_hw_device [lindex [get_hw_devices] 1]
INFO: [Labtools 27-1432] Device xc7z030 (JTAG device index = 1) is programmed with a design that has 1 ILA core(s) in it.
ERROR: [Labtools 27-1972] Mismatch between the design programmed into the device xc7z030 (JTAG device index = 1) and the probes file D:/VHDL/cdma_aiv/ZYNQ_ADC_TRK/zynq/Ade_test_proj.runs/impl_1/debug_nets.ltx.
 The core at location user chain=1 index=0 has different widths for ILA input port 0. Port width in the device core is 0, but port width in the probes file is 10.
Resolution: Make sure the device probes file is up-to-date, then re-program the device.
Re: Vivado chipscope error
This issue generally occurs when .bit and .ltx files do not match.
Make sure you are using correct .ltx file and .bit files.
Vinay
both .bit and .ltx are proper, still getting same error
Moving to Design tools -others board.
Thanks,Vijay
I checked in artix 7 also. i got same error
