Visitor chesh
Vivado makes AXI4-Lite to AXI4-Memory map if I use an additional Interconnect
If I use a AXI Interconnect to connect a peripherals with an AXI4-Lite connection it makes the connection between the AXI-interconnect of the Zynq and AXI Interconnect of my peripherals an AXI4-Memory mapped connection. This is shown in the screenshot below M12 AXI (blue line = AXI4-Memory Map Connection)
If I connect an AXI4-Lite peripheral directly to our AXI Interconnect of the Zynq it is an AXI4-Lite connection (Green line).
This requires more resources (~4% of our design).
An option is connect all my AXI4-Lite peripherals to directly to the Zynq AXI Interconnect but this becomes a mess. I would like to keep the block design hierarchical and use AXI Interconnect within sub blocks to connect several AXI4-Interconnect.
Is there any way to force the connection between 2 AXI-Interconnects to be AXI4-Lite?
Observer michellelloyd
Re: Vivado makes AXI4-Lite to AXI4-Memory map if I use an additional Interconnect
Hi @chesh,
Did you ever figure this out?
@michellelloyd
