Visitor fk5747
cannot connect another clk to dbg_hub
I am using Artix 7 Evaluation kit, and I wrote some simple VHdl code and now I want to connect the clk_in to the bebug core. The clk_in generates in the code:
i_clock_input : IBUFDS
generic map (
DIFF_TERM => FALSE,
IBUF_LOW_PWR => TRUE,
IOSTANDARD => "DEFAULT")
port map (
O => clk_in,
I => clk_in_p,
IB => clk_in_n
I have tried these tow lines in the XDC file:
connect_debug_port dbg_hub/clk [get_nets clk_in]
connect_debug_port u_ila_0/clk [get_nets clk_in]
now there are warning messages :
[Vivado 12-1419] Debug core 'dbg_hub' was not found.
[Vivado 12-1419] Debug core 'u_ila_0' was not found.
and it doent update the clk. Can anyone help me? Thanks in advance.
Re: cannot connect another clk to dbg_hub
Hi @fk5747 ,
How are you implementing the ILA? Are you instantiating it in Verilog/VHDL or are you using the Insertion Flow (Set Up Debug)? or a TCL script?
If you are using Verilog/VHDL instantiation, the XDC constraints will not work.
If you are doing Set Up Debug or TCL, you should be able to do so with the TCL commands you created (with a post-synthesis design open).
Open the TCL console and issue the command:
get_nets clk_in
Does that returns an object or an empty? If it returns empty, it's because it's not finding such clock in your design. So there might be some sintax issue or something.
Finally, at which point of the design flow you see the errors [Vivado 12-1419] ?
Andre Guerrero
Product Applications Engineer
Scholar dpaul24
@fk5747,
A debug block/core can have only 1 clock, which is the design clock. All other signals connected should be non-clock signals.
        ila_core_inst: ila_core
        port map(
            clk        => system_clk_i,
            probe0(0)  => signal1,
            probe1(0)  => signal2,
            probe2(0)  => signal3,
            probe3(0)  => signal4
The above is how a ILA core should be instiantiated. All signals, namely signal* above, must belong to the system_clk_i clock domain.
FPGA enthusiast!
All PMs will be ignored
Visitor fk5747
Thank you, but I dont understand your point.
Sorry I am new to Vivado.
Actually I have a problem that the VIvado connects a clk which is not a free running clock to debug core, therefore I follow the answe on below link
https://www.xilinx.com/support/answers/64764.html
and now I am here. Any suggestion?
Scholar dpaul24
@fk5747,
You want to connect the clk_in to the clock input pin of your debug core, right?
And you are not sure if clk_in  is a free running clock or not?
FPGA enthusiast!
Visitor fk5747
clk_in is a free running clock, I want replace another clk (which is a non-free running clock, and by default connects to the debug core) with clk_in. I hope it make sense?
Scholar dpaul24
@fk5747,
I cannot replace it with another clock which is not a free clock.
as it is mentioned in the AR you have posted, a non-free running clock can have problems. So avoid it!
FPGA enthusiast!
Hi @fk5747 ,
get_nets clk_in
Andre Guerrero
Visitor fk5747
Thank you.
I issue the command and I understand that clk_in is not connected to any module. Now it works.
