Visitor edthompson
iMPACT
I have installed both ISE Design 14.5 and 14.7. I have installed the license. Why is iMPACT greyed out?
iMPACT is the only tool I need to use and what I installed this for.
Re: iMPACT
Please check the below thread
http://forums.xilinx.com/t5/Configuration/iMPACT-Download/td-p/275756
You can also find useful information at below AR
http://www.xilinx.com/support/answers/12858.html
Ashish
Re: iMPACT
Attach a snapshot here that indicates impact is greyed out.
Also, try invoking the impact in below manner:
Windows: Start --> all Programs --> Xilinx Design Tools --> ISE Design Suite 14.x --> ISE Design Tools --> 64-bit tools --> iMPACT
Linux: run the command: impact
Vinay
Re: iMPACT
Have you run bitgen. Only after the bit file is generated, you will be able to open IMPACT from the ISE window. However you can open it as a standalone module as pointed out in the other replies.
Anirudh
Re: iMPACT
Moving to correct board.
Thanks,Vijay
