ila probe effect functionality of my design
Hi everybody
in my design i have an ila core that has some probes. if net that connect to probe no.7 is for example net no. 12 design work correct. but if net no. 13 connect to this probe design don't work correctly.
what is the problem?
Scholar drjohnsmith
Re: ila probe effect functionality of my design
its broken is all we can say from this.
a lot more info needed ,
device and tools
  what are u doing
     what do you mean by broken,
what do you mean by the numbers
a look at your code ?
device and tools :
artix 7/50t/-2
vivado 2017.4
what are u doing :
write to fifo and read from it
what do you mean by the numbers :
net no. 12 or 13 means 2 different nets in my design. in detail my fifo is common clk and if i connect fifo clk to one ila probes, output of fifo that i see in ila is ok if this net(fifo clk) not conneted to one ila probes output of fifo isn't correct.
Scholar drjohnsmith
sounds like a timing problem to the ILA,
have you tried putting some registers in the front of the ILA ?
     what frequency you cocking the fifo at ?
just check you have constant clocks into the fifo ?
a bit more detail would be of use,
The ILA, is routed, so it does affect the layout / timing,
      but provided you have timing constraints in place and correct it works great.
one other thing,
   does it simulate ok ?
what do you mean : "have you tried putting some registers in the front of the ILA ?"
fifo read and write frequency is 256 kHz
Scholar drjohnsmith
KHz is very slow, that should not be a problem,  !!
   out of interest , how do you generate such a slow clock ?
        I'd normally be clocking the fifo faster, but putting a lower frequency enable into it.
what clock do you put into the ILA ?
re registers and the ILA ?
when you make the ILA, you have option to add pre registers,
     if your clocking fast, it makes meeting timing easier for the tools.
if i clocked my fifo in this frequency Will there be a problem?
with a counter that counts faster clock period and generates slow clk.
2.048 MHz
what do you mean : re registers and the ILA ?
Scholar drjohnsmith
dont use gated clocks into fifos
they need constant clock into them
use your slow clock as the fifo enable
re registers in front of the ILA ,
when you made the ILA , there is an option to add pre registers,
   normally at 0, but if u had a fast clock, setting this to say 2 can improve layout / timing.
I don't feel thats its the ILA thats causing the problems here,
have you simulated ?
@drjohnsmith
if i use gated clk to fifo, what problems will happen?
if i connect slow clk to fifo enable, many false data will be written to fifo, this is not true(below image)?
"I don't feel thats its the ILA thats causing the problems here"
but i see like this problem in some other design (but rarely)
Scholar drjohnsmith
Generaly
Fifos need a constant clock into them,
   they have interesting clock crossing / synchronization circuits in them
What I'd normally do is :
generate an enable pulse, one clock high , when I want data written to the fifo.
   This would be at the same frequency as you slow clock, but only active when you have data to go into the fifo.
         and clock the fifos at a constant clock,
Asics use  lots of clocks, and gated clocks , but Fifo's tend not to in the main.
Can we see you code ?
   this sort of problem tend to be due to other problems in the code.
You don't seem to want to answer my question as to have you simulated ?
    does that mean you have not ?
:) , NO simulation is OK.
indeed i changed my code and a constant clk connected to fifo and problem has been fixed but because rarely i see this problem, in time i ask it...
Scholar drjohnsmith
Thats great news,  constant clock is what the fifo's need,
Great to hear about simulation working, thats always a good start.
Just make the enable to the fifo's one clock wide for the data you want
You seem less than confident about the results. Can we see your code, there might be some other pointers we can give you to get rid of your worries.
