IP Core doesnt generate Spartan-6
Hej all,
I am using the Spartan 6 XC6SLX45 - 3FGG676 FPGA and want to generate an 16k FFT IP Core within ISE.
I am getting this message
Qt: Untested Windows version 6.2 detected!
INFO:sim:172 - Generating IP...
WARNING:sim - VHDL simulation file type 'Behavioral' is not valid for this core.
   Overriding with simulation file type 'Structural'.
WARNING:coreutil - error deleting "C:/Users/Waleri
   Milde/Dropbox/Uni/Master/Masterarbeit/FPGA/TestFFT/ipcore_dir/tmp/_cg/_dbg/":
   file already exists
       while executing
   "file delete -force $transientDirectory"
       (procedure "::xilinx::GeneratorUtils::cleanTransientOutputs" line 21)
       invoked from within
   "::xilinx::GeneratorUtils::cleanTransientOutputs $componentInstanceID"
       (procedure "main" line 44)
       invoked from within
   "main $argc $argv"
       invoked from within
   "return [main $argc $argv]"
       (file
   "C:\Xilinx\14.7\ISE_DS\ISE\coregen\repository\xilinx.com\generators\customiza
ERROR:sim - Unable to evaluate Tcl file:
   C:\Xilinx\14.7\ISE_DS\ISE\coregen\repository\xilinx.com\generators\customizat
   ion_generator_v1_0.tcl
ERROR:sim - Failed executing Tcl generator.
ERROR:sim - Failed to generate 'IPFFT'.  Failed executing Tcl generator.
Wrote CGP file for project 'IPFFT'.
Core Generator create command failed.
I have no idea what this means....
As I understand from the docs I can generate an IP core but it doesnt work....
Best regards
Waleri
Re: IP Core doesnt generate Spartan-6
FYI: Moved to IP core forums board.
Check if below AR's help and also make sure you are using supported OS as it looks like you are using windows 8 which is not supported with ISE14.7
Supported OS can be found at page 7 of below doc
https://www.xilinx.com/support/documentation/sw_manuals/xilinx14_7/irn.pdf
https://www.xilinx.com/support/answers/55861.html
https://www.xilinx.com/support/answers/35824.html
https://www.xilinx.com/support/answers/62639.html
Satish
