Visitor ademski
Bootgen problems
I'm trying to use bootgen to generate a "full" BOOT.bin without good results.
The .bif that i'm using is:
//arch = zynqmp; split = true; format = BIN
image:
    [bootloader, destination_cpu=  r5-0]<PATH>/fsbl.elf
    [pmufw_image]<PATH>/pmu.elf
    [destination_device=pl]<PATH>/pl.bit
    [destination_cpu = a53-0]<PATH>/a53-0.elf
    [destination_cpu = r5-0]<PATH>/r5-0.elf
    [destination_cpu = r5-1]<PATH>/r5-1.elf
(the sources of each PU are FSBL,PMU and HelloWorld template)
With the a53 (x64) partition, the FSBL doesn't finish the PartitionLoad()
Then, taking a53 partition out, the FSBL finished OK but in the UART output shows that just one R5 is booting or both of them are executing the same code. I changed the helloWorld message to "Hello R5-0" and "Hello R5-1" and i just saw one of them on the UART. With this .bif, i see "Hello R5-1". If i change the R5's partition order, i see the other message.
I changed the "split=true" to false and regenerated the BOOT.bin. Surprisingly, there wasn't differences between both .bin (split= true and false)
Also, i tryied to change the load address of the r5-1 app, and the binary doesn't change.
So, i have the following problems:
- I can't boot A53 apps with de FSBL running in r5 processor.
- Just one R5 app is executed or both R5 are executing the same code in split or lockstep.
- The load attribute is not working when i set destination_cpu
Andres
Re: Bootgen problems
What address are each of your applications linked to?   Look at AR67506
Visitor ademski
IT WORKS!!
I changed the lscripts of all apps:
- Changed the r5's apps load addrs to TCM.
- Changed the a53's apps load addrs to DDR (ie: 0x100000).
Now, all procs are running standalone apps.
