HWICAP read frame function
Hi all,
I'm working on fault injection system on ZedBoard.
Through HWICAP I would read one frame, modify and rewrite it.
I'm using the example provided by Vivado SDK in which is called the function XHwIcap_DeviceReadFrame, but I don't understand how to choose the right parameter values to select a specific frame.
In the program is showed the following code:
* These are the parameters for reading a frame of data in
* the slice SLICE_X0Y0
#define HWICAP_EXAMPLE_TOP 0
#define HWICAP_EXAMPLE_HCLK 5
#define HWICAP_EXAMPLE_MAJOR 5
#define HWICAP_EXAMPLE_MINOR 10
Status = XHwIcap_DeviceReadFrame(&HwIcap,
HWICAP_EXAMPLE_TOP,
HWICAP_EXAMPLE_BLOCK,
HWICAP_EXAMPLE_HCLK,
HWICAP_EXAMPLE_MAJOR,
HWICAP_EXAMPLE_MINOR,
(u32 *) &FrameData[0]);
In the C file, the function parameters are explained as follow:
/************************** Function Prototypes *****************************/
* Reads one frame from the device and puts it in memory specified by the user.
* @param InstancePtr - a pointer to the XHwIcap instance to be worked on.
* @param Top - top (0) or bottom (1) half of device
* @param Block - Block Address (XHI_FAR_CLB_BLOCK,
* XHI_FAR_BRAM_BLOCK, XHI_FAR_BRAM_INT_BLOCK)
* @param HClkRow - selects the HClk Row
* @param MajorFrame - selects the column
* @param MinorFrame - selects frame inside column
* @param FrameBuffer is a pointer to the memory where the frame read
* from the device is stored
* @return XST_SUCCESS else XST_FAILURE.
* @note This is a blocking call.
But I don't understand the relationship between these paremeters and implementation floorplan.
Where can I find a documentations about the parameters meaning?
Thanks is advance,
Andrea
