Visitor o.passot.elg
MPSoc, psu_init.c stay in a loop during DDR eye training
Hi, I have problems on custom board initialization.
Soft Version Vivado/SDK/petalinux 2017.4
Board version: custom board including a Zynq XCZU6EG
When I boot the board with JTAG flow (using psu_init.tcl) there is no problem
When I boot the board with FSBL flow, psu_init.c stay in a loop in psu_ddr_phybringup_data() :
regval = Xil_In32(0xFD080030); /*PUB_PGSR0*/
while (regval != 0x80000FFF)
readback value = 0x840007FF which means:
write eye training done = 0
read eye training error = 1
There are 2 chips MT40A512M16JY-083E on the board configure in vivado like following screenshot
If I comment the loop in the psu_init.c and create a linux from new FSBL I can boot on linux but it’s freezing after a while.
When I run memory test using JTAG flow (psu_init.tcl) all is pass except read eye training which freeze sometimes (not always).
I think there is problem in my DDR configuration but I don’t find it.
Do you have any ideas?
Tags (3)
Re: MPSoc, psu_init.c stay in a loop during DDR eye training
DDR Configuration setting in PCW has less issue if it passed validation.
If the eye test didn’t pass, you would need to check your PCB.
Do you meet PCB guideline from ug583?
Visitor qiaoheng
If your question was solved ,please tell us how to solve it!! Thank you very much!
we meet UG583 guideline.
For the moment it works with the modification of init.c : I changed the DDR configuration (use NO DM, NO DBI) and it seams to be better
But I'm not sure it safe !
Do you have any more suggestion ?
Thx,
Have you made any progress?  I am having a similar problem, and would like to hear how you resolved it.
No, not any progress for the moment !
This setting depends on your DDR connection.
if you don’t use the DM and DBI pin, you need use NO DM, NO DBI setting
Visitor qiaoheng
You can try lastest version of the Vivado!
