Visitor shyamthella
ZC702 Uboot changes to load image.ub from SPI flash
Hi All,
I am able to flash BOOT.BIN to ZC702 spi flash using sf commands. But when I power cycle the board and try to boot it, its hanging at uboot command prompt. I believe U-boot needs some command defined to load image.ub from spi flash to RAM and execute kernel.
Can you tell me SPI address to load image.ub?
Also where should I load image.ub from flash using sf read to RAM? RAM location to read image.ub from spi flash.
Shyam
Re: ZC702 Uboot changes to load image.ub from SPI flash
If you use petalinux to generate the image, please find platform-auto.h from your project.
Then kernelstart shows the flash offset and netstart shows the load address of memory.
Visitor shyamthella
Thank you.
Can we load an extracted rootfs contents to spi flash?
I know how to use compressed rootfs fromflash using an itb file.
Xilinx tends to use .ub extension (i.e. Yocto generates the fitimage.itb or fit.itb file in deploy/images/<machine_name> directory and PetaLinux tools will rename this to image.ub while copying to <plnx-proj-root>/images/linux directory.)
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18842374/U-Boot+Images
Visitor shyamthella
Thats Okay. Iam now able to flash BOOT.BIN and my .itb file to SPI and boot it properly. I want to make changes that are made to my rootfs to be persistent over multiple boots. For this a compressed image will not help right. So I want to use extracted rootfs which is copied to SPI flash.
Will this is possible on ZC702?
Shyam
you can boot Linux with individual Kernel image, rootfs , device tree file.
See P.45
http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_7/ug873-zynq-ctt.pdf
Visitor shyamthella
Thanks for pointing it. But the command there says "dow -data uramdisk.image.gz 0x2000000" which is to copy a compressed ramdisk image to SPI flash. I told I want to use uncompressed ramdisk folder to be used as my file system. Is there a way to achieve this?
Shyam
