Visitor andrei.hres
ZynqMP brick mode
Hi.
For my custom ZynqMP board boot mode is QSPI. I debug remote system update (TFTP loader) for my board. During update process I have got error and now QSPI flash has unpredictable firmware image. Problem is that I can not errase the image (or all flash memory) and I do not have jtag acces to system. XSCT console shows me:
xsct%
xsct%
xsct% connect
tcfchan#4
xsct% targets
  1  PS TAP
     2* PMU
     3  PL
  4  DAP (APB AP transaction error, DAP status 10000021. No debug power)
xsct% state
state error: (Code 16 Time 1562677149711 Format {Invalid context})
xsct%
What can I do in this situation (change boot mode with hw pins is not very easy)?
Re: ZynqMP brick mode
You can try this in the FSBL you use as the guide file to program the QSPI from SDK (do not change the FSBL in your boot.bin):
Add the following change to in FSBL(xfsbl_initilization.c) and use this FSBL for Flash program in SDK
                * Read Boot Mode register and update the value
                BootMode = XFsbl_In32(CRL_APB_BOOT_MODE_USER) &
                                                CRL_APB_BOOT_MODE_USER_BOOT_MODE_MASK;
                //Add this line
                BootMode = XFSBL_JTAG_BOOT_MODE;
Visitor andrei.hres
Hi.
May be I can do this but JTAG dose not work. It is not easy to change boot mode pins to JTAG. Boot mode pins set to QSPI mode.
This is a change to the FSBL only, no need to change the boot mode pins on your device.   This will force the guide FSBL to run in JTAG boot mode regardless of boot mode pin settings, which should allow you to reprogram your QSPI device.
Visitor andrei.hres
I can not load FSBL becouse JTAG connection does not work (see my first post). I do not understend this situation completely, but I think there is some wrong boot.bin in QSPI. I think HW bootloader boots something and sends system to state in wich JTAG is off.
If your JTAG is disabled, you are forced to change the boot mode to JTAG to recover that.   There is nothing that can be done remotely if your boot image disables JTAG.   Are you booting a secure image?  By definition, secure boot modes disable JTAG.
AR 68381 discusses how to create an image that will enable JTAG -- but in your case you will need to change the boot mode to JTAG to regain access to your board.
Visitor andrei.hres
I boot non secure image. But boot process was interrupted.
What caused the boot interruption?   Can you reboot and recover from that?
Visitor andrei.hres
May be is method to restore the board without boot mode pins replacement?
It sounds like your QSPI image is sending the board into a bad state.  The only way I know of  to recover from a bad image is to boot in JTAG boot mode.
Visitor andrei.hres
I stopped it by myself (TFTP client on my PC was stopped).
Visitor andrei.hres
What means row in XSCT console
from my first post?
You can look here
Scholar drjohnsmith
I had a similar problem,
got around it with a lump of solder across some of the QSPI pins, so the device would not boot,
then JTAG seemed to work,
Did not chase any more,
and its probably a totaly different problem, but just may be ?
