2 microblaze cores connected Via FSL in the new EDK 11.1
Hello everyone,
I'm working on a project that connects 2 microblazes via FSL. I'm using the new version of EDk, 11.1
so basically, this new version supports the dual core design in the BSB.
Please i need to know, is there something else in the design that i should update by myself or does EDK do all the work for me, should i update the mhs and mss files?
Thank you,
Nadidjka
Nadidjka
It depends what version you upgrade from.
If you upgrade from 10.1.3 then the upgrade wizard will tell you, if there is something that can't be automatically upgraded.
Göran
Göran
Thank you Goran :)
Nadidjka
Nadidjka
