ACP port for Zynq board[BD 41-1629] </processing_system7_0/S_AXI_ACP/ACP_M_AXI_GP0> is excluded from all addressable master
Hi, I'm trying to use the ACP port instead of the HP port for Zynq board. But when I try to validate the design, the following error appeared: [BD 41-1629] </processing_system7_0/S_AXI_ACP/ACP_M_AXI_GP0> is excluded from all addressable master spaces.The following is the block design.
Re: ACP port for Zynq board[BD 41-1629] </processing_system7_0/S_AXI_ACP/ACP_M_AXI_GP0> is excluded from all addressable master
Hi @ssong94,
Please check the address editor tab and see if the slave is mapped.
If not try auto assign address.
Arpan
Hi @ssong94,
Arpan
According to your method, I have encountered such a problem. Can you tell me how to solve it?
You can choose "Include Segment", then the segment will be included and auto addressed.
pear
What could I do when ip is seem like "unconnected slaves" ?
