ADC/DAC Tutorials ?
Hi everybody.
I have to implement a DAC and an ADC on my Spartan-3A 3400 DSP Edition with EDK 10.1.
I have the IP : XPS Delta-Sigma DAC (http://www.xilinx.com/support/documentation/ip_documentation/xps_deltasigma_dac.pdf) and XPS Delta-Sigma ADC (http://www.xilinx.com/support/documentation/ip_documentation/xps_deltasigma_adc.pdf).
I just want to know if someone can give me tutorial(s) for this DAC and/or this ADC, and if someone can say me what are the FPGA´s pins I have to use.
Fabien.
Re: ADC/DAC Tutorials ?
I find the solution of my issue... In my code, I have to add:
  XDsAdc_mEnableConversion (&ADC);
Best Regards,
Fabien
I'm working whit the Spartan-3A 1800 DSP, in the implementation of basic ADC; in the external circuit required, which are the values of R and C in the low pass filter?.  I already implemented a project in XPS to show in the led's avaliables the sample took by the ADC; i added the ip cores required, modified the UCF file, implemented the external circuit (comparator + low pass filter), build a software project whit respectives ADC and GPIO functions but it didn't works.  SOMEBODY HELP US.
thanks
Hi aguachicorio, did you find the solution of your issue ? Because I get the same problem... Here is my C program:
/* ADC PROGRAM */
#include "xparameters.h"
#include "stdio.h"
#include "xutil.h"
#include "xdsadc.h"
//====================== MAIN =============================
int main (void) {
u16 ADC_OUT;
XDsAdc ADC;
if(XDsAdc_LookupConfig (XPAR_XPS_DELTASIGMA_ADC_0_DEVICE_ID))
xil_printf("Configuration OK \r\n");
if(XDsAdc_Initialize (&ADC, XPAR_XPS_DELTASIGMA_ADC_0_DEVICE_ID) == XST_SUCCESS)
xil_printf("Initialisation OK \r\n");
while(1)
ADC_OUT=XDsAdc_ReadInput (&ADC);
xil_printf("ADC_OUT=%x \r\n", ADC_OUT);
return 0;
  And the result is always :
  Initialisation OK
  Configuration OK
  ADC_OUT=0 ...
Fabien
Message Edited by fabiend on 08-21-2009 02:25 AM
Best Regards,
Fabien
Newbie imtiazs
ADC/DAC Tutorials
hi,
can anyone help me for getting   ADC/DAC Tutorials  bcos iam working on edk tool, so need to interface  ADC/DAC with spartan II pro.. so plz i request if u have any such kind of tutorials let me know......
thanks.....
Message Edited by imtiazs on 02-19-2010 05:36 AM
Message Edited by imtiazs on 02-19-2010 05:39 AM
Scholar pumaju1808
hi,
i want to implement a simple example of ADC on  my Spartan 3E board, i want to use the ADC Chip that comes with the board and use the J7 header to my analog inputs.
Also i want to use XPS_Delta Sigma core, but i am a little confuse, becase the pre-amplifier and ADC chips on the board have SPI interface but XPS Delta Sigma i do not see any SPI ports, so my question is how is ADC chip related with XPS Delta Sigma core?? or they are two different things??
In this post i see a C program using XPS Delta Sigma but can you please give more details of how do you connect your analog signal??, do you use the on-board ADC chip???
thanks for your help
Scholar pumaju1808
Someone can give an idea of how "link" XPS Delta Sigma and the on-board DAC of Spartan 3E??
In what kind of hardware do i need use XPS Delta Sigma, what i need to have connected to my FPGA board??
thanks
what should be the connection of input and output port of adc?
IM2INTC,
Agtr,
DACout,
and Sample?
if i made IP2INTC 'no connection',
and make the proper connection with other ports, then i got a error in genarate netlist
the errore is in line 69 in mhs file,its saying
 ASSIGNMENT=REQUIRE is defined in
   the MPD. You must specify a value in the MHS.
 ASSIGNMENT=REQUIRE is defined in   the MPD. You must specify a value in the MHS."
the 69th line of mhs file is
" 67. PARAMETER C_HIGHADDR = 0x00001fff
  68. BUS_INTERFACE SLMB = dlmb
 69.  BUS_INTERFACE BRAM_PORT = dlmb_port
 70. END"
I am new in edk platform of xilinx,working on spartan3e ,
i never add any Ip with my project,
now i want to connect deltasigmaadc. i added the ip core, and make pin connection,
but in my block diagram i saw adc is disconnected, I added the block diagram,
and i found an error in my mhs file, i think my adc is dis connected,
pls advise me
is there anyone to rply??
ami i right that my adc is not connected to bus accorditng to attached picture??
pls give some suggestions
here i added the adc ip to my project,but its giving some error. i think adc is not connected,what should i do?can i edit mhs file maually?
i attached a picture where you can see the block diagram
i locate the problem,
the ports are are not generating automatically in the mhs file.
In that case what should i do?!!
could u tell me the pin no of these ports
IM2INTC,
Agtr,
DACout,
and Sample
Visitor celojan
Conexion SPI ADC/AMP
The correct solution for the pin's conexion, you can see in the above graphic. The SPI module is a IPCORE spi 2.01a, and the GPIO is an IPCORE of general propouse for I/O. Its  one bit of lenght for output.
Newbie cheeseboy
I know this post is old but I am having this problem still.
I am using the Spartan e3 board. I tried adding the xps_delta-sigma ADC IP using Xilinx Platform Studio (EDK), and connected it to the mp_plb bus. I used the following code when programing but I am getting only 0 values, even when i pull VINA to vcc:
/* ADC PROGRAM */
#include "stdio.h"
#include "xutil.h"
#include "xdsadc.h"
int main (void) {
u16 ADC_OUT;
XDsAdc ADC;
XDsAdc_EnableConversion (&ADC);
while(1)
return 0;
Can someone provide me with how they connected their ADC using the XPS(EDK)? Do i need to change the .ucf file? Do i need to add connections to the IP2INTC_Irpt, AgtR, DACout, Sample?
What am i doing wrong in the design?
-Omri
