aishwaryab
ADV7511 Xilinx Evaluation Boards Reference Design
I am trying to implement ADV7511 Xilinx Reference Design on zc702. When I build the project in SDK, I am getting the following error:
c:/xilinx/sdk/2017.4/gnu/aarch32/nt/gcc-arm-none-eabi/bin/../lib/gcc/arm-none-eabi/6.2.1/../../../../arm-none-eabi/bin/ld.exe: cannot find -llibHDMI_ZynqLib.a
collect2.exe: error: ld returned 1 exit status
make: *** [sw.elf] Error 1
Can someone help me with solving this error?
Aishwarya
florentw
Hi @aishwaryab,
Where did you find the reference design? Are you using the recommended vivado/SDK version for it?
Florent
aishwaryab
Hi Florent,
Thank you for your reply.
I downloaded the reference design from the following link:
https://wiki.analog.com/resources/fpga/xilinx/kc705/adv7511
I am using Vivado 2017.4.
Do I need to use 2016.4 version only?
Aishwarya
aishwaryab
Hi @florentw,
I tried using Vivado/SDK 2016.4 version as well. I am still getting the same error.
ERROR:
c:/xilinx/sdk/2016.4/gnu/aarch32/nt/gcc-arm-none-eabi/bin/../lib/gcc/arm-none-eabi/5.2.1/../../../../arm-none-eabi/bin/ld.exe: cannot find -llibHDMI_ZynqLib.a
florentw
Hi @aishwaryab,
It depends on which version you checked out on git. IF hdl_2017_r1, yes you need to use 2016.4.
Then did you follow all the steps from the tutorial, specifically this one:
"In the same window, go to Settings→Libraries and add the path of the lib folder and the name of the library used. For a Zynq based platform the name is HDMI_ZynqLib (libHDMI_ZynqLib.a on Github) and for a Microblaze the name is HDMI_MicroblazeLib (libHDMI_MicroblazeLib.a on Github)"
Florent
aishwaryab
Hi @florentw,
I am using hdl-2017_r1 and no-OS-2017_R1 and using 2016.4 version.
I followed each and every step of the tutorial. But still no good.
Aishwarya
florentw
Hi @aishwaryab,
Could you share a screenshot of the window configuration for Settings→Libraries?
Did you try to re-click on apply?
Could you try another path for the library?
Florent
manoj_kumar0007
Hello Sir,
           I am using Vivado 2017.4 ..which version of reference designs of ( ADV7511) i should use ? kindly provide the link ..
I am getting following errors when i implemented the design (2017_r1) in ADV7511 reference designs.
ERROR: [BD 5-106] Arguments to the connect_bd_intf_net command cannot be empty.
ERROR: [Common 17-39] 'connect_bd_intf_net' failed due to earlier errors.
    while executing
"connect_bd_intf_net $m_name_1 $m_name_2"
    invoked from within
"if {[get_property CLASS $m_name_1] eq "bd_intf_pin"} {
    puts "connect_bd_intf_net $m_name_1 $m_name_2"
    (procedure "ad_connect" line 40)
    invoked from within
"ad_connect  sys_ps7/DMA0_REQ axi_spdif_tx_core/DMA_REQ"
    (file "/home/xenoverze/Desktop/adv7511/hdl-hdl_2017_r1/projects/common/zc702/zc702_system_bd.tcl" line 178)
    while executing
"source $ad_hdl_dir/projects/common/zc702/zc702_system_bd.tcl"
    (file "system_bd.tcl" line 2)
    while executing
"source system_bd.tcl"
    (procedure "adi_project_xilinx" line 101)
    invoked from within
"adi_project_xilinx adv7511_zc702"
    (file "./system_project.tcl" line 6)
Thank you.
aishwaryab
Hi @florentw,
I have tried different path as well tried re-clicking on apply.
Aishwarya
florentw
Hi @aishwaryab,
Did you do it for both Debug and Release configurations?
Florent
