AMP on Zynq starting from SDK
Used system:
- Zynq with two baremetal processors
- SDK 2015.2
- followed Developing Zynq Software with Xilinx SDK Lab 9 Dual Processor Software Development
When generating app_cpu1_bsp(standalone_amp bsp)for amp,i encounter these errors in SDK Log as follows:
21:18:39 ERROR : [Hsi 55-1545] Problem running tcl command ::sw_standalone_amp_v3_11_a::generate : invalid command name "xget_libgen_proc_handle"
while executing
(procedure "::sw_standalone_amp_v3_11_a::generate" line 8)
invoked from within
"::sw_standalone_amp_v3_11_a::generate standalone_amp"
[Hsi 55-1442] Error(s) while running TCL procedure generate()
21:18:39 ERROR : Error generating bsp sources: Failed to generate BSP.
21:18:39 ERROR : Failed to generate sources for BSP project standalone_amp_bsp_0
org.eclipse.core.runtime.CoreException: Internal error occurred while generating bsp sources. Please check the SDK Log view for further details.
at com.xilinx.sdk.sw.ui.handlers.RegenBspSourcesHandler.internalGenerateBsp(RegenBspSourcesHandler.java:178)
at com.xilinx.sdk.sw.ui.handlers.RegenBspSourcesHandler.access$2(RegenBspSourcesHandler.java:163)
at com.xilinx.sdk.sw.ui.handlers.RegenBspSourcesHandler$1$1.run(RegenBspSourcesHandler.java:131)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2345)
at com.xilinx.sdk.sw.ui.handlers.RegenBspSourcesHandler$1.run(RegenBspSourcesHandler.java:135)
at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:121)
any ideas?Thanks!
Re: AMP on Zynq starting from SDK
Can you try using the 2015.2 files from here:
