AP Transaction timeout when loading elf file
I am using vivado 2016.2 for zynq
After Programming FPGA with bit, when try to load .elf  error  pops up when process reach to 98% as
  AP transaction timeout
Does anyone has suggestions on it
Re: AP Transaction timeout when loading elf file
This error normally occurs when the memory region is not accessible. Can you run memory tests from OCM and check if the original region you were trying to load the elf to has any issues
