10-19-2013 10:59 PM
I am using ZC702 Eva. Kit. When I tried to program it I get the following error. Software tool used vivado 2013.2
Programming Bitstream -- E:/Workspace_Vivado/ZC702/project_2/project_2.sdk/SDK/SDK_Export/hw_platform_0/system.bit
Fpga Programming Progress .............10.........20.........30.........40.........50.........60.........70.........80.........90........Done
Error:
AP transaction error (DP CTRL_STAT=0xf0000021)
Error Address = 0x00100000, Size = 0x00000004
Please let me know, what could be the problem.
Jothi
10-20-2013 12:59 AM
10-20-2013 01:10 AM
10-20-2013 11:11 PM
I am using SDK flow. I tried rst -debug_sys. Still I get the same error
10-21-2013 11:22 AM
The reason I asked the flow was that this looks like an initialisation issue of your Processor System, the error message mentions:
This is the DDR have you configured your DDR correctly in the Processing System IP configuration before exporting to SDK?
If you are using a Demo board, you should use the predefined settings in the import settings in the config gui for this IP,
then re-export to SDK
10-21-2013 06:32 PM
10-22-2013 01:25 AM
10-22-2013 08:02 AM
Thank you for your response. I get the following msg
XMD% mrd 0x00100000
ERROR: Cannot Read from target
Cannot access DDR: the controller is held in reset
Jothi
10-22-2013 08:31 AM
i have attached a zip here. can you download and unzip and try the following?
Can you try the following XMD commands:
cd to where ever you downloaded the zip
connect arm hw
source ps7_init.tcl
ps7_init
ps7_post_config
stop
mrd 0x00100000
note: i used 14.6. if you are not using 14.6, you can leave out the ps7_post_config step
10-23-2013 12:23 AM
XMD% source ps7_init.tcl
couldn't read file "ps7_init": no such file or directory
XMD% ps7_ini
XMD% ps7_init
XMD% ps7_post_config
XMD% stop
Processor stopped
XMD% mrd 0x00100000
100000: 00000000
XMD% mwr 0x00100000 0xA5A5
XMD% mrd 0x00100000
100000: 00000000
XMD% mwr 0x00100000 0xA5A5A5A5
XMD% mrd 0x00100000
100000: 00000000
XMD%
But I am not able to download the elf file
10-23-2013 03:23 AM
ok, well this is good news. There is nothing wrong with your board. The issue was with the init of the PS. Cam you follow the tutorial below:
http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_7/ug873-zynq-ctt.pdf
10-23-2013 07:13 AM
Thank you. I have been using this board for quite some time. This is working when I run this on ram memory. This is having problem only when I try to run on DDR3.
10-23-2013 12:14 PM
10-23-2013 06:48 PM
10-23-2013 11:36 PM
Hi Jyothi ,
It seems that the DDR is not configured properly.
Can you do the diagnostics for the DDR to confirm that memory is working.
Jangi reddy
10-27-2013 08:50 AM
02-12-2015 06:59 PM
06-12-2017 04:12 AM
10-23-2017 08:53 PM
What are the configurations you are expecting for DDR before exporting to SDK.
