sriramv90
ARM DS-5 and ZYNQ 706
I am currently working on debugging the ARM A9 core on the ZYNQ 706 SoC. I have a fully licensed version of DS-5 along with DSTREAM device. I saw in an example document that zynq 702 can be debugged with DS-5 Dstream. Is it the same procedure for Zynq 706 as well? Is there any design document for Zynq 706?
Thanks in advance,
Sriram
Tags (4)
smarell
Community Manager
Community Manager
There are no documents for ZC706.
sriramv90
But, technically it should be possible to use DS-5 with 706 right?
Sriram
smarell
Community Manager
Community Manager
Yes it should be possible.
sriramv90
Thanks a lot.
Sriram
