ARM processor programming using Xilinx SDK
I use SDK to program Microblaze and Zynq ARM. But I want to ask, is it possible to program other ARM processors like MSP430 with SDK?
If yes, how can setup SDK(toolchain,compiler options..)?
Berker
Hi Berker,
No, SDK doesn't support other ARM SoCs
Hi Berker,
OK thanks
