AXI Address Translation in packaged IP
I have a packaged ip project that contains a block diagram with an address map and an axi memory mapped input [slave port]
I have another block with two axi master outputs that route out to the hdl.
I need to connect two instances of the slave block to the master block in the hdl.
I can't seem to work out how address translation works for this [below are screenshots to serve as an example]
If I instantiate just one slave block - it is accessible at 0x00000000 [its offset address]
The addressing in the master block appears to make no difference to where the slave is mapped.
Is there a generic I'm supposed to be passing?
Block diagram
Address Map
Packager settings
Outer block
Outer addressing
Re: AXI Address Translation in packaged IP
So the answer to all this is that when in the hdl layer - all address translation is done by hand.
An exposed axi master does no address translation as it passes into the hdl
Visitor audiodane
Is there an AXI address translator available? That would seem to be a (relatively) simple IP block to produce. I just ran into that tonight not knowing that an AXI port passed to HDL has no address translation performed.
I suppose I can understand why that might be desirable, but it sure would be nice to have it as a selectable feature (translation vs pass-through)!
..dane
http://audiodane.dandk.org
