rs2015
AXI BFM IPI example design has errors
I downloaded the AXI BFM example design from  AR# 62769
I opened the project using Vivado 2015.3 and I get a bunch of errors after upgrading the IP:
Any help appreciated.
pvenugo
Here is updated project for 2015.3 and I have changed simulator setting to Vivado.
You can change to your preferred simulator as well.
Praveen
