rebelsequeira
AXI Quad SPI issues
I am trying to instantiate an AXI Quad SPI in the PL of the Ultrazed board.
My constraints file is as below.
set_property PACKAGE_PIN AB7 [get_ports io0_t_0]
set_property PACKAGE_PIN AA7 [get_ports sck_t_0]
set_property PACKAGE_PIN AB8 [get_ports ss_t_0]
set_property PACKAGE_PIN Y7 [get_ports io1_t_0]
set_property BITSTREAM.GENERAL.UNCONSTRAINEDPINS Allow [current_design]
I noticed another thread with similar issues and I have followed everything he has done --> https://forums.xilinx.com/t5/Processor-System-Design/Coding-AXI-quad-SPI/td-p/742653
I see my chip select line go low on the scope. Although I do not see a clock pulse on the clock line. I am trying to understand what I am doing wrong?
My code is as below.
/***************************** Include Files *********************************/
#include <stdio.h>
#include "platform.h"
#include "xil_printf.h"
#include "xparameters.h" /* XPAR parameters */
#include "xspi.h"
#include "sleep.h"
//#include "psu_init.h"
/************************** Constant Definitions *****************************/
* The following constants map to the XPAR parameters created in the
* xparameters.h file. They are defined here such that a user can easily
* change all the needed parameters in one place.
#define SPI_DEVICE_ID XPAR_AXI_QUAD_SPI_0_DEVICE_ID
* This is the size of the buffer to be transmitted/received in this example.
#define BUFFER_SIZE 17
/**************************** Type Definitions *******************************/
* The following data type is used to send and receive data on the SPI
* interface.
typedef u8 DataBuffer[BUFFER_SIZE];
/***************** Macros (Inline Functions) Definitions *********************/
/************************** Function Prototypes ******************************/
int SpiPolledExample(XSpi *SpiInstancePtr, u16 SpiDeviceId);
/************************** Variable Definitions *****************************/
* The instances to support the device drivers are global such that the
* are initialized to zero each time the program runs.
static XSpi SpiInstance; /* The instance of the SPI device */
* The following variables are used to read and write to the Spi device, they
* are global to avoid having large buffers on the stack.
u8 ReadBuffer[BUFFER_SIZE];
u8 WriteBuffer[BUFFER_SIZE];
int main(void)
init_platform();
int Status;
* Run the Spi Polled example.
Status = SpiPolledExample(&SpiInstance, SPI_DEVICE_ID);
if (Status != XST_SUCCESS) {
return XST_FAILURE;
//return XST_SUCCESS;
cleanup_platform();
return 0;
init_platform();
//psu_init() ;
int Status;
//u32 Count;
XSpi_Config *ConfigPtr; /* Pointer to Configuration data */
* Initialize the SPI driver so that it is ready to use.
ConfigPtr = XSpi_LookupConfig(SpiDeviceId);
if (ConfigPtr == NULL) {
return XST_DEVICE_NOT_FOUND;
Status = XSpi_CfgInitialize(SpiInstancePtr, ConfigPtr,
ConfigPtr->BaseAddress);
return XST_FAILURE;
Status = XSpi_SetOptions(SpiInstancePtr, XSP_MASTER_OPTION | XSP_MANUAL_SSELECT_OPTION);
return XST_FAILURE;
XSpi_Start(SpiInstancePtr);
* Disable Global interrupt to use polled mode operation
XSpi_IntrGlobalDisable(SpiInstancePtr);
xil_printf("%d",XSpi_GetStatusReg(SpiInstancePtr));
u8 WriteBuffer[BUFFER_SIZE]={0xB3,0x03,0x1F,0x00,0x00,0x00,0xC0,0x53,0xA1,0x13,0x00,0x0A,0xCC,0xCC,0x31,0x8E,0x00};
// u8 ReadBuffer[BUFFER_SIZE]={0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
XSpi_SetSlaveSelect(SpiInstancePtr, 0x01);
* Transmit the data.
while(1)
XSpi_Transfer(SpiInstancePtr, WriteBuffer, NULL, BUFFER_SIZE);
* Compare the data received with the data that was transmitted.
/*for (Count = 0; Count < BUFFER_SIZE; Count++) {
xil_printf("\n read %d",ReadBuffer[Count]);
xil_printf("\n write %d",WriteBuffer[Count]);
if (WriteBuffer[Count] != ReadBuffer[Count]) {
print("fail");
return XST_FAILURE;
print("\n success");
return XST_SUCCESS;
2019-10-21 16_24_49-PMOD_QuadSPI - [C__Users_rebel.sequeira_Documents_dev_Ultrascale-Freertos_Vivado.png
rebelsequeira
Turns out, i couldn't use the tri state pins. I used the input and output pins correctly and that seemed to fix the issue.
rebelsequeira
