AXI Quad SPI transfer width problem
We are using Vivado 2013.4 and Zynq7030 and AXI Quad SPI IP to make single 32-bit SPI interface.  When testing with our proto we get only 29 clock cycles instead of 32 clock cycles.
AXI Quad SPI Vivado configuration is attached below. SPI mode is selected by SW. Mode selected is Mode 0 (CPOL = 0 and CPHA = 0).  Any glue what’s wrong?
Best Regards,
Ville-Veikko
Re: AXI Quad SPI transfer width problem
I have run a quick simulation with 2014.1 and it seems to be fine.
I believe that this issue is already fixed in 2014.1
--Hem
We also used AXI Quad SPI IP in standard transfer mode at 16 bits transaction. In testing we get only 15 clock cycles ....strange.
Anyone has any idea from this issue?
We have done our 32-bits long SPI transfers with four 8-bits transfers and keeping slave select low all the time with SW. Anyway it would be nice to have a solution/comments on this.
This is a known issue with the IP and is scheduled to be fixed in 2014.1
However you can try using the 8-bit mode, this was able to work as expected.
--Hem
OK. 2014.1 is already published....I have not installed it.
Do you mean that this is ALREADY corrected in 2014.1 ....or scheduled to be fixed in some future release?
--Hem
